VoLTE on Xpeeia 1
  • September 11, 2024
  • 65 views
David Quinn
I have an Xperia 1 (J8110) which I see on the list of compatible phones but I don't have an option for 4g calls. I read elsewhere that the network provider can enable this but I cannot see how.
Best answer by WelshPaul
The UK Xperia 1 doesn’t support VoLTE.
  • 8584 replies
  • September 12, 2024
Hi @David Quinn
Have you reset your network settings while the SIM card is inside the Xperia 1?
It’s possible it wouldn’t be a choice per say but would automatically switch between Wi-Fi/4G calls only if the signal isn’t strong enough for regular calls.
David Quinn
  • September 16, 2024
Thanks, yes, I rest network settings and also tried setting to 4g/3g/2g (the only option with 4g). Calls don't work, text and data are fine. Strangely if it's on then attempts to call to the phone ring for the caller but not on the phone. If the phone is on airplane mode then calls to the number go to voicemail.
  • 3157 replies
  • 8584 replies
  • September 19, 2024
Hi @David Quinn
It may be worth visiting the following;
https://community.idmobile.co.uk/3g-200/3g-was-switched-off-in-my-area-and-i-can-t-make-calls-what-should-i-do-60533
However as @WelshPaul suggests, if your device doesn’t support VoLTE, you may continue to have issues.
