what is my phone number
  • 22 June 2021
  • 12 views
So, in order to activate the SIM I need my phone number, which i don't have because I was never sent one - how do I fix this?
I just transferred today and with the sim card I got a receipt which has the phone number, I agree is not easy to find but there is a telephone number there.. and if you insert your card in your phone then you will get a message with the number.
You only need to activate a replacement SIM @Ewan Burns.
If the SIM was received as part of a new order then just pop it in the phone and you should be good to go. 👍
Hello @Ewan Burns,
If it’s a new contract SIM, then the SIM will already be active upon dispatch.
You can pop the SIM in and send a text to a friend/family and ask them to confirm the number (or call).
You’ll need the number to register, not activate though (since it’s already active).
Let us know if you still need help.
