Why does 4G not work
Jocelyn Brett
It says it has full bars but there is no signature at all. I can call and text but no Internet. Honestly the ID is worst network, I'm paying a lot of money for data that I can't even use!!
Best answer by Tom
Hi @Jocelyn Brett
I’m sorry to hear this, please could you let us know the postcode(s) where you have this issue?
What device are you using your SIM card in?
How long have you had this issue?
  • 12545 replies
  • June 18, 2024
Perhaps it’s time to think about switching to another service provider, @Jocelyn Brett.
  • 8584 replies
  • June 19, 2024
Hi @Jocelyn Brett
  • August 28, 2024
Hello
My 4G is not working. Why has this suddenly happened? I am on unlimited plan. I need help urgently but cannot find an email to contact IDMobile for assistance so trying here and hoping someone can help resolve this issue. My postcode is sw19 and I am using an iPhone. Thanks
  • 5394 replies
  • August 30, 2024
Hey there @Natalie68, we're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please do email us on socialqueries@idmobile.co.uk so we can look into this further for you.
Kind regards,
