why is incoming 0330 number blocked
I have missed several important NHS health screening calls because they begin with 0330 and are blocked. They go straight to voicemail which is no good because I call back and rearrange then the call is blocked again! How do I stop this happening?
  • March 11, 2025
Ok. I added the number to my contacts and it still got blocked. I went to phone setting and the number had been added to my blocked list - not by me! So I have unblocked it. How do I stop this happening with future 0330 calls as I have now missed 2 urgent medical calls 😡
  • 8408 replies
  • March 11, 2025
Hi ​@Sharonbromley
Is your bill cap at £0?
We may be blocking what we believe could be a chargeable call, if you’re sure it isn’t you may want to raise the bill cap and try again.
  • March 11, 2025
That’s not the reason. It isn’t set at zero
  • 4297 replies
  • March 12, 2025
Hey there ​@Sharonbromley, we’re very sorry to hear that.
Do you also have premium features enabled via the iD Mobile app/website?
Just to check, are you able to call these numbers at all?
  • March 12, 2025
 this was an incoming call that was blocked and when I rang it back I got thru but my appt had been missed. The problem is why are 0330 incoming calls blocked?
  • 12408 replies
  • March 12, 2025
Maybe the number is blocked on the phone with your iD SIM, ​@Sharonbromley.
Otherwise, it might be necessary to switch to a service provider where this behaviour doesn’t happen.
Numbers beginning 03 are included in iD plan calls allowance, and they don’t seem to be listed anywhere in iD online information (about charges) covering out-of-plan number use.
  • 4297 replies
  • March 13, 2025
Hey there ​@Sharonbromley, sorry to hear that.
Do other 0330 numbers work okay for you?
  • March 13, 2025
I don’t know as I’ve not had any other incoming 0330 calls
  • 8408 replies
  • March 14, 2025
Hi ​@Sharonbromley
Okay, are all other standard calls working as normal?
They can call you and you can call them?
  • March 14, 2025
Yes
  • 8408 replies
  • March 14, 2025
Hi ​@Sharonbromley
