I have only been with Id mobile for a couple of weeks and have burned through 100gb of data already! I was on EE for years with only 5gb of data and never went over, I am not using my phone any differently at all, so I am really confused and worried about the extra charges for being over my data allowance!
why is my data usage increased so much on ID mobile compared to my previous EE data when i use the phone the same
Best answer by Tom
Sorry to hear this, this may be a change in the usage or in the speeds you get, if you’re accessing 5G connections you may be using more data and quicker than you would on 4G.
To avoid any extra charges, we’d recommend using a bill cap.
Reply.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
