WiFi calling issues
  • December 27, 2024
  • 221 views
Just switched to a new iPhone 16 Pro Max and having issues with WiFi calling not working..
I have full WiFi signal but only 1 bar of 4G. Calls do not send or receive, they do work when I toggle WiFi calling off though.
If I swap the SIM back to my old iPhone 14 (sitting right next to my new phone) everything works fine..
Forum|alt.badge.img
  • 9 replies
  • December 28, 2024
what i can suggest, just try
celular  network, where is your id network, your number- add your number +447xxxx
This trick saved me when the wi fi ca.ling has not worked on my iph 12…just try and see if something will be change
  • 4170 replies
  • December 30, 2024
Hey there ​@Gazza 3166, sorry to hear that.
When you go into settings, is your phone number showing, and showing correctly?
Have you tried resetting network settings?
