WiFi calling not working
Julie X
Hi ,I have a message on my screen "WiFi calling not available for SIM 2 (which is new iDmobile sim)"all is activated in settings, for both Sims (SIM 1 is by different provider).I've done all the suggested: rebooted, toggled Airplane mode on off, nothing helps. Is it a faulty SIM? Thanks
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 362 replies
  • April 7, 2025
@Julie X  This may be due many thing's, if you've done all the checks put the IDMobile Sim card from sim location 2 to location 1 and the other network into Sim 2 see if this results in a change.
Wi-Fi calling can often be used with both SIM cards on a dual-SIM device, but this depends on the carrier, device, and specific settings. Ensure both SIMs are compatible with Wi-Fi calling and that your device supports the feature for both SIMs.
Joe
  • 3801 replies
  • April 7, 2025
Hey there ​@Julie X, thank you for reaching out.
Please try the kind advice from ​@JoeKing and let us know how it goes, as this is the same suggestion we’d make initially.
If it doesn’t help, please let us know so we can investigate further.
