WiFi Calling Not Working on Pixel 8 Pro
  • July 29, 2024
  • 260 views
I'm trying to use WiFi calling on my Pixel 8 Pro. I've followed the instructions to turn WiFi calling on in settings, and according to the approved handsets lists the Pixel 8 Pro should work with WiFi Calling on the iD mobile network.
Even when WiFi calling is turned on, I notice that in the settings menu it still says “Call over mobile network” - there is no option to change this.
Also when I try aeroplane mode with WiFi on, I get a message saying I'm not connected to a wireless network.
Software is up to date (Android version 14).
Any other ideas?
Best answer by Matthew T
Hey @callumjethomas,
Please try using the + (Country Code) prefix when dialling. If you’re calling a UK number this is +44 7xxx xxxxxx.
  • 1862 replies
  • August 2, 2024
