Hi, will WiFi calling or 4G calling work on the Motorola Edge 40 Pro?
It’s not currently in the compatible list, although the Edge 40 and 40 Neo is.
Have you tried using the WiFi Calling with your Moto Edge 40 Pro,
If iD WiFi Calling works, there’s a good chance iD 4G Calling will also work - both of these network services should use the same IMS on the iD network.
