WiFi Calling on Motorola Edge 40 Pro
Hi, will WiFi calling or 4G calling work on the Motorola Edge 40 Pro?
It’s not currently in the compatible list, although the Edge 40  and 40 Neo is.
Have you tried using the WiFi Calling with your Moto Edge 40 Pro, @madden1978
If iD WiFi Calling works, there’s a good chance iD 4G Calling will also work - both of these network services should use the same IMS on the iD network.
  • 12167 replies
  • June 26, 2024
  • June 26, 2024
Hi @andewhite  thanks for the reply.  It does appear to work, although it never shows ‘ID Mobile WiFI Calling’ on my device.  I guess this may be because the model isn’t on the compatible list?  thanks again.
  • 3820 replies
  • June 28, 2024
Hey there @madden1978, thank you for reaching out.
If it does work for you, then that’s great news! If it doesn’t, then the likely reasoning is if it’s not on the supported handsets I’m afraid.
