I see this phone not being present on the Wifi calling compatibility list, but is the support going to be added soon Or is it up to the manufacturer? This is an Android One device with Android 9 currently on it.
Wifi calling on Motorola X4?
Best answer by Mohammed H
Hello
Thanks for your request, we’ll pass this to the Team internally however, we may not be able to give an answer as to whether this will be added or not.
Log in to the iD Community.
