Wifi hot spot
Afternoon all, I'm trying to work out a GPS solution for my motorbike.
If I have a cheap old phone mounted to the bars, taking WiFi from a hot spot on my good phone (in my jacket), will I be billed for the data use?
Short version, are there additional fees for using my phone as a WiFi hot spot, assuming i remain in my permitted data?
Thanks!
Best answer by Natalie W
Hi ​@TwoOrThree
You can use your mobile data to HotSpot from and charges would only apply if you exceed your data allowance.
To avoid unexpected charges, you may wish to set a £0 spend cap via the iD Mobile app as this will prevent chargeable data being used if the allowance is exceeded.
We  will also notify you via text once you have reached 80% and 100% of your allowance.
Please let us know if you have any further questions.
Natalie
Forum|alt.badge.img+21
  • 2255 replies
  • April 5, 2025
Hi ​@TwoOrThree
Natalie
  • April 17, 2025
Brilliant, thank you for your help.
  • 4297 replies
  • April 18, 2025
You’re very welcome ​@TwoOrThree :)
  • April 18, 2025
You did not provide an answer, Natalie did.
  • 3054 replies
  • April 18, 2025
Both ​@Natalie W and ​@Tyler are iD Mobile employees. ​@Tyler was simply responding to your last post as a courtesy on behalf of iD Mobile.
  • 2255 replies
  • April 21, 2025
Hi ​@TwoOrThree
Happy to help :)
Please get in touch if you have any further questions or concerns.
Natalie
