Will Wifi calling on ID work if it works for my device on another network?
  • November 1, 2019
  • 96 views
If Wifi calling (vowifi) works on my unlocked device on Three, should it work on ID?
If you can’t be certain, is there any way of testing?
Could I buy an ID SIM for one month and try it, cancelling it if it doesn’t?
Thanks!
nrsp
Mohammed H
  • 7962 replies
  • November 4, 2019
Hello @nrsp,
Which device is it that you’re using?
You can find a list of the compatible devices here: https://www.idmobile.co.uk/help-and-advice/wifi-calling
You can always purchase a SIM from us and test it. If you purchase this from our website, you have 30-days returns. After this, it’s simply 30-days notice whenever you wish to cancel as you wouldn’t be tied into any long contracts on SIM-only plans.
