ZTE MU5001
I’ve just received my ID sim which I intend to use in my ZTE modem.
I’ve been using a popit sim which works off EE so I’m aware I need to change the APN settings.
I don’t seem to be able to find the required settings?
Can anybody help?
Best answer by Geluk
My id sim worked as soon as I put in router; have you tried doing that. Settings in sim should populate necessary router settings.
  • 12421 replies
  • July 24, 2024
  • July 24, 2024
Thanks but those are for phones this is a modem
  • 12421 replies
  • July 24, 2024
Okay @Getawywithjules, pretty sure every mobile phone has a modem.
A mobile phone without a modem wouldn’t be able to modulate / demodulate the radio waves carrying the signal data.
FYI, iD Mobile don’t support use of an iD SIM in anything other than a mobile phone, sorry.
  • July 24, 2024
Sorry my mistake I meant Router.
So I guess it won’t work I’ll have to cancel then.
Geluk
Silver Contributor
Forum|alt.badge.img+10
  • Silver Contributor
  • 464 replies
  • July 24, 2024
Tom B
  • 8408 replies
  • August 1, 2024
Hi @Getawywithjules
It may be worth checking the above from @andewhite, however it’ll be worth noting that no routers are officially supported for usage with an iD Mobile SIM card, it’s possible they’ll work but we cannot guarantee it.
