charged for ringing a mobile no.
Peter Aldridge
Hi, just looking through my March bill and have been charged for a call to a mobile no. Please advise, thanks, Pete
  • 8225 replies
  • March 7, 2025
Hi ​@Peter Aldridge
When calling a non-standard number, or possibly a number roaming, you may be charged extra.
https://www.idmobile.co.uk/help-and-support/premium-rate-services
Peter Aldridge
  • March 7, 2025
Hi Tom
thanks but the number was 07893 950***. Not roaming either
Pete
  • 8225 replies
  • March 7, 2025
Hi ​@Peter Aldridge
Decembersangel72
Silver Contributor
Hi ​@Peter Aldridge
The number you are enquiring about is a ‘non-standard’ 07 number and hence is charged at 40p/min.
Here is a link to these types of numbers and which ones you will be charged for:-
https://media.secure-mobiles.com/idmobile/documents/non-standard-07-numbers-v2.pdf
In your case, it is labelled as a ‘FM10 Mobile’.
I can’t explain what is meant by this code in the ‘BT Wholesale Category’ column as they’re not explained anywhere on the iD Mobile website.
Definitely an oversight by iD and would be a great help to explain them.
Hope this helps x
Peter Aldridge
  • March 9, 2025
Hi ​@Decembersangel72
Thanks so much, I understand now!
I am waiting for a private message back from iD, but yes, they do need to explain as was on the line for 25 minutes.
Also, the number was my contact in Octopus energy.to do with ordering a heat pump. Naughty!
Thanks again
Decembersangel72
Silver Contributor
Glad I could help ​@Peter Aldridge 👍🏻
I didn’t know Octopus had that contact number🤔 (as I am also with them).
The only one that I know of is 0808 164 1088 for their Customer Service.
And calling 0808 numbers from an iD Mobile phone is free, just like calls to 0800 numbers.
Where did you get the ‘07893 950***’ number from? I don’t think they would have a ‘non-standard’ contact number so please be careful as this appears to be a scam contact number.
This is the webpage with regards to Octopus Energy Heat Pumps
https://octopus.energy/order/heat-pump/#our_claims_explained
And if you scroll down to ‘Contact Us’ you will see it is also an ‘0808’ number.
Hope this clarifys things x
Peter Aldridge
  • March 15, 2025
Thanks again,
It’s not a scam, it’s the number the sales guy called me on, and as I missed the call I rang back.
Everything above board, and showing on my Octopus account, and installation booked, just had no idea of
the cost of calling it!
Cheers again
  • 3719 replies
  • March 17, 2025
Hey there ​@Peter Aldridge, thank you for letting us know.
I see we’re in discussion via PM with yourself, so will keep you updated and discuss further there.
Of course you’re more than welcome to share anything else here too for others to see/discuss!
