Cost of images via RCS
Sending an image via SMS incurs an extra charge, but what about sending the image via RCS?
The cost of using RCS comes out of the data allowance of your iD plan, @derrickw
RCS requires a network connection, by using a Wi-Fi network, or the iD mobile data network. There’s no extra charge for the image as such.
FYI, the iD Mobile MMS can’t send any images larger than ~384KB.
  • 12428 replies
  • June 27, 2024
  • July 9, 2024
Hi @derrickw,
I hope that @andewhite has answered your query.
  • August 10, 2024
That is false, Ive just used google messages  RCS and have been charged 55p for an MMS message!
  • August 10, 2024
Kash wrote:
Hi @derrickw,
Youre wrong that was not the correct answer
Also why is the default charge cap is £75 if was 0 my message wouldnt have gone and I would have use WhatsApp.
Ive set the cap to £0, so I won't get caught out again!
I do not trust ID RCS messages now.
Regards
Ken
Tom B
  • 8408 replies
  • August 15, 2024
Hi @Kenw
The above is in-fact correct, if you were charged 55p for an RCS MMS message, it was not an RCS message, that’s what we charge for MMS over our texting network.
RCS would go outside of our own SMS system (Similar to that of iMessage, WhatsApp, Messenger etc).
  • August 15, 2024
No your  reply is  not accepted.
My reply is why did I have GB£75 cap , if it had been £0 the message should not have gone!
iD set the CAP do they are at fault! And always be as far I'm concerned.
This another example of ID not being truthful, the other is not telling customers that when connected to a WiFi network the mobile data is limited. This is per Ofcom coverage checker contrary to ID/3 checker
Regards
  • August 21, 2024
Hi @Kenw,
If you didn’t select a cap when purchasing your cap would go to the highest amount of £75.
Please let us know if you would like us to check your cap and when it changed.
Michael Nesbitt
My current bill is showing at £10 more than I am contracted to pay how can I see what extra charges are being billed.
Tom B
  • 8408 replies
  • September 26, 2024
Hi @Michael Nesbitt
You’ll be able to use the iD Mobile app once registered/logged in to see bills and charges.
Michael Nesbitt
That doesn't answer my question. I want to monitor my billing in real time as I could with other providers.
Tom B
  • 8408 replies
  • October 1, 2024
Hi @Michael Nesbitt
The app is updated however not in real time, it may take a few minutes or longer for usage you’ve made to show on the app itself.
Michael Nesbitt
Hi Tom
I cannot find this option on my app. Can you outline how to find it. Cheers
Tom B
  • 8408 replies
  • October 5, 2024
Hi @Michael Nesbitt
Usage is found on the home page on the app, as soon as you log in the first page.
Michael Nesbitt
Remaining usage is not the issue. I want to see what costs I am running up Before the bill is issued. I could do this on previous networks but not it seems with ID
Lauren K
Forum|alt.badge.img+19
  • 479 replies
  • October 8, 2024
Hi @Michael Nesbitt, if you run up any extra charges, you’ll receive a text message in advance advising you on this.
Your invoice is also generated 14-days before payment is due and you’ll be able to view a bill breakdown via the iD app or your account online.
-Lauren
AllanSMW
  • 9 replies
  • December 20, 2024
Kenw wrote:
Kash wrote:
Hi @derrickw,
Regards
Ken
Found a setting in Google messages that if your recipient can't receive RCS it tends as SMS unless turned off.
Not helped by Samsung deprecating RCS in its own messaging app and pointing people to use Google 💩
https://www.forbes.com/sites/zakdoffman/2024/12/09/googles-rcs-nightmare-why-you-need-a-new-app/
  • December 20, 2024
I have group messages using mms disabled, instead send individual texts also auto download MMS is disabled.
I have 2 Sims now, ID esim for data only and Lebara (Vodafone) for calls and texts, I'm contemplating paying up iD (3) to ditch.
Thanks for your response.
Samsung I believe now use Google rcs
AllanSMW
  • 9 replies
  • December 20, 2024
Samsung WERE using it for the default app on galaxy devices but not any more. Check now (and see the news article). I found this thread after recieving an MMS for first time in a decade...
  • December 20, 2024
I don't have a Samsung, so their change to Google messages doesn't affect me, I'm a pixel owner also I don't have RCS enabled.
The article states
The irony has continued for Google, with the news that Samsung is ditching RCS for millions of its Galaxy users still using Samsung Messages and recommending they switch to Google Messages. The Galaxy maker warned Verizon users that “Samsung Messages will no longer support RCS after 1.6.2025. Switch to Google Messages to maintain the more robust messaging you're used to.”
  • December 21, 2024
Hi ​@Kenw,
Thanks for the update.
We’ll keep that in mind for any future queries.
