Data roaming using wi-fi abroad | iD Mobile Community
  • September 30, 2024
  • 229 views
I have just signed up for an upgrade plan with 40GB data. I have just received a text saying I have gone over my 30GB data roaming allowance. But when abroad I have only used wi-fi for data and switched off data roaming. I cannot understand why it is suggesting I have used mobile data.
Best answer by Matthew T
Yes @Fatemabibi - as it’s a Greek Island you can use up to 30GB. Thanks.
  • October 3, 2024
@andygale35 -
Please disregard the SMS it’s ben sent in error. Thanks.
  • October 8, 2024
Can I use my data for roaming in Santorini?
  • October 8, 2024
  • October 8, 2024
Thank you for the response.  I read this online
  • October 9, 2024
Even better @Fatemabibi - Use as much as you like then (within your allowances!) as Greece is in our Roam Free destinations! Thanks.
  • October 9, 2024
Can someone tell how to set cap on my roaming please?
  • October 10, 2024
@Fatemabibi -
This guide should help. Thanks.
