Help understanding how ‘30 day rolling 20GB £6 a month SIM’ works
  • July 2, 2025
  • 95 views
I’m a bit confused on how the ‘30 day rolling 20GB £6 a month SIM’ works.
Could you please confirm the following:
Upon the initial 30 days ending, could I then instead use only PAYG balance for a while, and then later return to the same month plan?
Thank you
  • 6657 replies
  • July 2, 2025
Hey there ​@Zak96, thank you for your question.
30-day rolling SIM cards are simply 1-month contracts, that you can cancel whenever you like essentially. It just means it’ll keep rolling-on each month until you potentially change plan or decided to cancel.
You cannot however change/downgrade from a 30-day rolling SIM or pay monthly contract down to PAYG I’m afraid.
