Do I have unlimited hot-spot?
How to check it I can't hotspot
Best answer by Tom
The amount of data you have depends on your tariff, we’d recommend checking the iD Mobile app to see how much data you get per month.
You’re not limited on how much you can use to hotspot, just in general on data.
Reply.
