Lanzarote question
Hi,  Going to Lanzarote on Monday.  i have a sim only deal.  will i be charged using my mobile whilst there.  I have 399gb rolled over.
Lanzarote is an inclusive roaming roaming destination, @Rwj1968.
You can use your UK plan allowances out there, but your roaming mobile data may be limited to 30GB/month, depending on when you joined iD.
  • 12293 replies
  • June 29, 2024
  • June 30, 2024
Thank you andewhite
  • 8369 replies
  • July 15, 2024
Hi @Rwj1968
Roaming while in Lanzarote (Spain) is inclusive to your plan.
We’d recommend checking the below for how much data you’ll be able to use while roaming;
