overcharged bill after changing plan
  • December 24, 2024
  • 157 views
I was on £6 plan No contract, today I changed it to £18plan unlimited data, just after that I saw a bill showing on my account £29.00, I don’t understand why is that ? even I capped bill to £00.00 ! So can someone explain me why ID billing me incorrectly ?
#i recommend everyone No one should use this Poor Network, absolutely frustrating
Best answer by Tom
Hi ​@khadiza Rahman
After having changed your plan or made an upgrade, your bill may look and appear a little strange, the short version is, it’ll work itself out in time and should you be overcharged, you’ll be credited on your next bill.
  • 12303 replies
  • December 24, 2024
Have you check the length of billing period, for the bill with the higher than expected amount, ​@khadiza Rahman
Sometimes when you change or upgrade your iD plan, the bill immediately afterwards has a billing period longer than 1-month.
This community article might help.
Forum|alt.badge.img
  • Helpful
  • 15 replies
  • December 25, 2024
Hi have you contacted id mobile because it could be because when you change your plan
They charge in advance for your new package.
  • 8369 replies
  • December 26, 2024
Hi ​@khadiza Rahman
