Paid £10 plan not showing on account
Paid £10 plan not showing on account using app or webpage
davimac wrote:
I have just used the sim in a TP Link MIFI and data speed test worked. I don’t agree with reply received
Well if something should happen to go wrong with the SIM, it will be interesting to see how you get help from iD, @davimac.
All I said was use in a non-mobile phone device wasn’t supported, not that it wouldn’t work.
Anyway, happy days.
  • 12167 replies
  • June 14, 2024
Any sign of this £10 plan, when calling 7777 from your iD SIM card, @davimac?
  • June 14, 2024
This sim used to MIFI device only. I have deleted app twice and all it shows is “something went wrong try again” this message also on the webpage.
  • 12167 replies
  • June 14, 2024
Unfortunately @davimac, iD SIM cards are only approved and supported by iD when used in a mobile phone.
  • June 15, 2024
ID Mobile is happy to take my money(£20) not impressed.
  • June 15, 2024
  • 12167 replies
  • June 15, 2024
Anyway, happy days.
  • June 15, 2024
Update the chat help desk has actioned my payment plan to my account. It was said that there had been maintenance and an App update that caused this issue. The App and Webpage are linked hence why they are showing the same error “opps..Something Went Wrong” ongoing no indication when it will be fixed.
Aside from this I have  inserted the ID Sim into my TP-Link MIFI device and played YouTube video, this worked ok. The Dongle App is showing a txt confirming purchase of plan, and I can see data used thus far.
thanks for help
davimac
  • June 16, 2024
Hi All
I have checked the ID App and I can now see my current data used.
Thanks to everybody’s help and support.
Davimac
  • 8225 replies
  • July 3, 2024
Hi @davimac
While you may be able to use your SIM card in a dongle or similar device, it isn’t officially supported, so if it doesn’t work there, there wouldn’t be much we can do to support.
The app/website would be completely separate to the device you use it in however, glad to hear it’s now working for you.
