Will i be charged more if I get G5 speed
  • November 4, 2024
  • 51 views
Farshad
Hi. Will I be charged more as I am getting 5G now or am I still on 4G?
Best answer by Daz_S
Hi @Farshad
No you will not be charged more to use 5G
Assuming you have a 5G capable phone you’ll see 5G wherever it’s currently available. When you leave a 5G enabled area your phone should drop back to 4G.
However if you have a limited data allowance on your account you may find that due to how quick things download you may hit any limit sooner than you could have on 4G.
If you’ve got unlimited data then clearly you won’t have a data limit
HTH
Daz_S
  • 1627 replies
  • November 4, 2024
Hi @Farshad
HTH
  • 8756 replies
  • November 5, 2024
Hi @Farshad
Nope, you wouldn’t be charged more for using 4G or 5G.
However, if using 5G, you may use more of your allowance quicker, given the speeds are much quicker and you may be using it more/quicker.
Farshad
  • November 7, 2024
Thank you most kindly Mr. Tom and HTH Daz S.
Take care
Daz_S
  • 1627 replies
  • November 7, 2024
No problem @Farshad
(Just Daz_S as the ‘HTH’ means hope this helped😉)
And you 👍
Farshad
  • November 7, 2024
Sorry. I get it now..HTH. Thank you kindly. Have a great week Daz.
