Hi I’m trying to get a pack code from ID mobile
I sent a text to 65070 and it said there is a problem.
I’ve tried calling 77770 need to be transferred back to the app
i’ve use the app but it said there is a problem
can anyone help please
Best answer by Ryan D
We’re sorry to hear about this! We will send you a PM now so we can help further.
