Recently moved to ID, phone says 4G but can never get an internet connection. Any ideas?
4G connection?
Best answer by Lauren
It’s possible that 3UK is not as strong in your local area which could be why the coverage is affected. If it’s occurring everywhere you go, the issue points more likely to a handset or SIM fault.
However, from your screenshot, this suggests that this is a temporary local outage. Just so that you’re aware, the website itself updates every half an hour with any new information, and will let you know once the issue has been resolved if this hasn’t been rectified already.
-Lauren
Log in to the iD Community.
Social Login
Log in with FacebookPlease enter your email address. If it matches our records, we'll send you instructions to reset your password.
