Ive got 5G signal 3 bars and most calls wont connect as if it times out, those that did the quality is so bad i cant have a conversation. Just switched to ID from O2 so hope this isnt the service I expect
5G reception but quality is rubbish
Best answer by Kash M
All networks will have different levels of coverage in different areas as the coverage is dependent on the mast locations.
Some networks will have better coverage in some areas than others.
Log in to the iD Community.
Social Login
