Blackview A55 Pro and Mobile Data
I moved my Sim card to my new Blackview phone but I can’t access mobile data. My phone becpomes redundant if I don’t have access to wifi. Blackview support suggest I update the APN. Can anyone tell me how to do this.
Best answer by Joonee
Thanks but have discovered that iD doesn’t support Blackview phones. Have wasted hours trying to get this to work. So frustrating.
  • 12408 replies
  • June 8, 2023
  • June 9, 2023
  • 12408 replies
  • June 9, 2023
Do any of the UK mobile networks support Blackview phones?
  • 7962 replies
  • June 12, 2023
Hey @Joonee,
We don’t support this device as one of the approved handsets.
You can try the APN settings to see if this works.
I have a Blackview A70 and used the APN settings above, but also with
APN protocol: IPv4
APN roaming protocol: IPv4
And that works (those additional settings were for A7 but works ok).
