call charges
will i get charged for receiving calls when in turkey
Yes you will @JohnsonM - though only if your iD account bill cap is high enough to cover the charges.
You’ll be charged £2.40/minute, using your iD SIM to answer calls in Turkey.
  • 12479 replies
  • June 3, 2024
  • June 3, 2024
Thanks @andewhite. If I put my phone on divert to my wife’s phone who is on 02 will I get charged for the call divert ?
  • 12479 replies
  • June 3, 2024
Probably @JohnsonM - I think iD would charge for calling the O2 SIM at the calling UK from Turkey rate (also £2.40/minute).
Perhaps let your calls go to your iD voicemail, then use your spouse’s O2 SIM to call your iD voicemail.
Just make sure you set a PIN for your iD voicemail before going to Turkey.
Curious to know, do O2 have inclusive roaming for Turkey?
  • June 3, 2024
@andewhite 02 have a bolt on which is £6.99 per day for unlimited minutes, text & data.
