Can I block specific unwanted calls?
It's not uncommon to block unwanted calls with a block list, but I can't find any mention of such a feature. Is it possible?
You’d need to check the user guide for your mobile handset, @Phebmuccv
The network operator doesn’t normally block unwanted calls.
  • 12535 replies
  • May 15, 2024
  • 8484 replies
  • May 20, 2024
Hi @Phebmuccv
As suggested above, I’d recommend checking your device’s guide for this, we wouldn’t block the callers via the network.
Thanks for the help here @andewhite.
