Data plan reduced
In emails from iD, my data plan is 20Gb.  I have just logged in to the new website system and see that my plan is shown as only 8Gb.
Why/
Best answer by Tom B
Hi @Landyman130
Sorry to hear this, does the app still show as 8GB?
Please let us know so we can get in touch and double check on our side.
Mine showed similar but eventually updates. I have posted to express my displeasure to the upgrade in another post.
  • 6 replies
  • May 22, 2024
Self reply !
I’ve just ordered a third SIM and after the order was completed (on my PC), I was given the option to login.
I then saw that the correct data Gb values for both existing SIMs had been corrected.  Rather odd.
  • 6 replies
  • May 22, 2024
iD is one of many companies that are very annoying to deal with these days, however they offer the best deals.
Tom B
  • 8408 replies
  • May 27, 2024
Hi @Landyman130
  • 6 replies
  • May 28, 2024
Tom wrote:
Hi @Landyman130
Thanks Tom.  I replied in “Self reply !” above.  It corrected itself later.
Not tried the app only on my PC.
Generally apps are a waste of time.  Previously, I spend more time updating them before being able to use them.  So now generally don’t use apps.
  • June 3, 2024
Hi @Landyman130,
No worries, please let us know if you require further assistance.
If you do, please get back to us here.
