Want to get new iPhone 16, which is eSIM but old phone has physical sim. How do you do this and keep same number?
esim and physical sim
Best answer by Tom
The UK version of the iPhone 16 is both physical SIM and eSIM compatible I believe, however if you do need an eSIM, it may be worth checking the following;
