eSim setting for iphone 15
  • August 11, 2024
  • 141 views
I’ve replaced my physical SIM with an eSIM on my iPhone 15. I cut and pasted the carrier instructions from ID to manually add the eSIM. I’m now a bit baffled by the iPhone settings which I’ve had to play around with to get the eSIM to work. These settings work - but are they the optimal settings?
My phone settings are
Default voice line Primary
Mobile data; Primary
Allow mobile data switching
SIMs
Primary data On (mobile phone number)
Secondary On
5G data on for both
If I turn off Secondary then I lose all mobile and data.
Could someone share their eSIM settings that work on their iPhone please. I’m not confident I’ve set the iPhone up for best performance.
Best answer by Davesoa
Solved - the answer was (and I should have thought of this), take out the old redundant SIM. I thought, wrongly, I could just leave it in the phone.
  • August 11, 2024
  • 4697 replies
  • August 16, 2024
Hey there @Davesoa, we’re glad to hear all is sorted!
