Gmail doesn't send or receive
Hi, i have just moved over from Three network and brought my original number with me. I am using an old one plus 3 phone but for some reason, the Gmail app doesn’t send or receive mail to the phone.
Everything else seems to work fine but clearly something is wrong somewhere. I have tried deleting the app and reinstalling it again, removing the email address and putting it back on but i just can’t figure it out. I wonder if I’m having a senior moment here :)
Thanks for any help provided.
Forgot to mention, Gmail works fine when I use my wifi
Steve
Will
  • 4103 replies
  • August 29, 2020
That does sound odd @smig.
Have you tried logging into your Gmail through the browser, and then once signed in, selecting to “View in App”?
Will
  • August 29, 2020
Hi Will,
Thanks for getting back to me.
I found the answer by luck more than anything lol. It was an issue with google apps, they kind of take over everything don’t they.. I disabled and reset Gmail and it seems to work fine now.
Simple when you have luck on your side!
Thanks again :)
Kevin M
  • 2535 replies
  • August 29, 2020
Good to hear things are working @smig, so was it essentially that you logged out and back in to your Google Account?
Or was there more to it than that?
