I can't use my phone to call out or text.
My phone is saying that I'm not registered on a network.
How do I fix it?
How do I fix it?
Best answer by Kash M
Have you registered for the new iD Mobile account/app?
Once registered you’ll be able to login and manage your account.
It may also be worth checking the coverage and network status at the link below:
