Hi, I am not recieving any incoming calls or texts since I ported my number from Lebara
I can make calls and use data but I am not getting any incoming calls or texts, when I send text to my own number I receive it and I tried requesting help from ID customer service but no resolution found yet, I need few one time passwords to access some apps. So could someone please help me how do I fix this? Thank you.
Have you tried a Network Reset on your handset @Santhosh Palla
  • 12198 replies
  • June 21, 2023
Yes I did try it but didn’t work, I reset my entire phone too but still didn’t work, changed my sim into different phones still didn’t work.
  • 12198 replies
  • June 22, 2023
If your iD SIM card doesn’t work in several different phones @Santhosh Palla, it sounds like your iD SIM needs to be replaced.
My sim card does work, I can make calls and use data, I can receive calls from one or two people but not everyone, no text messages at all. I bought in a replacement sim but I was told by customer service changing sim does not do anything. @andewhite
  • 12198 replies
  • June 22, 2023
Okay @Santhosh Palla, community members can’t check the iD account of a customer.
I’d suggest using Facebook Messenger, or sending a Twitter DM (direct message) to speak with customer support about getting your incoming calls & texts working - following your number transfer to iD Mobile (from Lebara).
These support teams work until 8pm on weekdays (and 6pm at weekends).
  • 8192 replies
  • June 26, 2023
Hi @Santhosh Palla,
Sorry to hear that you have had issues after your port.
Please let us know here if you still require assistance and we would be happy to help.
Hello Kash, Yes unfortunately the calls and texts are still not working. @Kash
  • 8192 replies
  • June 27, 2023
@Santhosh Palla,
