How do I move over from o2?
how do i move from o2?
Best answer by JoeKing
Contact your provider and as for a PAC (Porting Authorization Code) or
How to switch and keep your mobile number
If you want to switch and keep your existing phone number, text ‘PAC’ to 65075 to begin the process.
PAC are valid for 30 day's once you have this you can submit the code to IDMobile or any other provider.
Log in to the iD Community.
Social Login
