How to enable WiFi calling on LG V30
I'm a little lost on this issue, as this phone has information on the net about using WiFi calling but it's not in your list of compatible phones.
Could you please confirm either way, and if not currently possible, advise how/who might make this happen?
Many thanks.
Many thanks.
Best answer by Gregor
Hey @Blinkertoon
Since this model is not supported by iD Mobile there is very little they can do to help you. When I had Xperia XZ1 Compact which is not supported either, it took me a while to get it to work by flashing different versions of firmware and the one branded by o2 made the trick.
Kind Regards
View originalSince this model is not supported by iD Mobile there is very little they can do to help you. When I had Xperia XZ1 Compact which is not supported either, it took me a while to get it to work by flashing different versions of firmware and the one branded by o2 made the trick.
Kind Regards
Log in to the iD Community.
Please note: Log in with Facebook is no longer available. If you used this service, you'll need to create a password to keep using the iD Community. Click 'Forgot Password?' to get started.
