I'm not receiving incoming calls from NHS
  • September 26, 2023
  • 306 views
Jean Meynell
Hi I'm getting important calls from NHS but my phone isn't ringing, just vibrating once and there is no answer button to answer the calls
Best answer by WelshPaul
Sounds like you may have added the number to your block list. What phone do you have?
  • 3066 replies
Jean Meynell
  • 6 replies
I have a google pixel 6 pro
  • September 29, 2023
@Jean Meynell,
Can you check that the number isn’t blocked.
  1. Open your Phone app .
  2. Tap More More.
  3. Tap Settings and then Blocked numbers.
  4. Next to the number that you want to unblock, tap Clear Clear and then Unblock.
Jean Meynell
  • 6 replies
Sorry but it's not a blocked number but thank you anyway
  • October 1, 2023
Hi @Jean Meynell,
Is the software up to date? Do you get issues with any other numbers?
It may be worth testing it in another handset as it may be a handset issue.
Jean Meynell
  • 6 replies
  • October 1, 2023
My phone did a software update at the beginning of the week and unfortunately I don't have another handset I can try my sim in
  • 8408 replies
  • October 3, 2023
Hi @Jean Meynell
Have you been able to accept calls from the number before while on iD Mobile or never?
