i order a sim a while ago haven't received it i believe I need a replacement sim i
Ieuan
I haven't received my SIM I've tried logging into the my account I've got the right number that I was emailed but maybe cusy last name is weird it says something wasn't right even tho I set it up I just need a replacement SIM so if one of your community people can help I'd be great full thanks
Ieuan wrote:
I got my SIM from Curry's the person their told me to tell you lot so you can activate it or something
Hey @Ieuan, you’ll need to do this online at https://my.idmobile.co.uk/ja/web/cpw/sim-swap
  • 12550 replies
  • January 3, 2024
It might be quicker to get your replacement iD SIM card from your nearest Currys store @Ieuan
  • 8584 replies
  • January 4, 2024
Hi @Ieuan
What date did you place your SIM only order?
As @andewhite suggests, the quickest way to get a replacement SIM card would be to pick one up from a Currys store, it can then be activated at the following link;
Ieuan
  • January 16, 2024
  • 12550 replies
  • January 16, 2024
  • 8584 replies
  • January 16, 2024
Hi @Ieuan
You’ll be able to activate your replacement SIM at the link above from @andewhite.
