imessage and facetime not activating
Mia Anne
My iMessage and FaceTime will not activate and keeps coming up with error- I HAVE TRIED THE FOLLOWING MULTIPLE TIMES! And doesn’t work!! SOMEONE HELP!
Maybe visit an Apple store and see if any in-store staff can assist activating the Apple iMessage and FaceTime services, on your Apple iPhone.
Otherwise, perhaps ask Apple to explain why activating the Apple iMessage and FaceTime services is an iD Mobile issue.
  • 12459 replies
  • January 3, 2024
Have you tried turning your iPhone OFF for at least 30-minutes?
Have you spoken to Apple support?
Is this your first iPhone, or have you upgraded?
Both iMessage and FaceTime are Apple services, which require a data connection. However, most activation issues seem to sort themselves out after a few days, which is frustrating.
Mia Anne
  • January 3, 2024
This is my 4th iPhone. Never ever had an issue before.
yes I have turned my phone off for 40 minutes.
i called Apple and they said it’s an ID issue.
  • 12459 replies
  • January 3, 2024
Are you a new iD customer?
If yes, is the mobile number you wanted to keep still linked with your ‘old’ iPhone?
Mia Anne
  • January 3, 2024
No the number has ported over and my number on settings is showing my number I want to keep
  • 12459 replies
  • January 3, 2024
Okay @Mia Anne, perhaps Apple have linked the number you wanted to keep to another iPhone that you own/owned?
Apple register your mobile number against the Apple iPhone device ID, and having the same mobile number linked to different iPhone devices might cause a problem with the Apple activation process.
Mia Anne
  • January 3, 2024
Ok, so what am I meant to do now?
  • 12459 replies
  • January 3, 2024
Tom B
  • 8434 replies
  • January 4, 2024
Hi @Mia Anne
When you make a call outbound to someone, does the correct number show on their side or the incorrect one?
I’d recommend the above from @andewhite, the iMessage/FaceTime service isn’t one we at iD operate, this is likely in the hands of Apple.
