incoming calls cut off after 2min 5sec
Since September, some incoming calls just end, no message or anything, just stop.
Looking at the call logs, these calls all end after 2 minutes and 5 seconds.
It is random, some days it wonts happen, other days it will happen continually until I call the person back, then it does not happen. Only happens on incoming calls.
My wife has changed phone and SIM supplier and still it persists when she calls me. Leads me to think the problem is my phone.
My phone is an Xiaomi Redmi Note Pro 5G.
Any sort of ideas to combat this frustrating issue would be welcome.
Njames59 wrote:
Thanks for the reply @andewhite
Forgot to put in the original message that my phone is a Note 12, which appears on the list you linked.
I bought the phone and SIM through ID Mobile, so I hope they are trouble free.
So, maybe I have a faulty SIM? I probably need to ask for a new one.
If these issues started Sep-2023, perhaps an Android update (on your Redmi) is to blame.
Otherwise, if nothing else has changed, maybe your iD SIM card has developed a fault.
A faulty SIM card seems able to cause various mysterious service issues - so a replacement might be the answer in this case, and is worth a try.
  • 12258 replies
  • January 17, 2024
Perhaps somehow you’ve got a faulty SIM card, @Njames59. Otherwise, maybe your Redmi handset isn’t approved by iD Mobile, for completely trouble-free use of their network.
Check this online at https://www.idmobile.co.uk/help-and-advice/approved-handsets.
  • January 17, 2024
  • 12258 replies
  • January 17, 2024
Lauren
Forum|alt.badge.img+19
  • 479 replies
  • January 19, 2024
Hi @Njames59, we’ll be able to investigate this further. We’ll try out a replacement SIM, and then investigate further if required.
-Lauren
  • January 25, 2024
Hi Lauren
I have changed the SIM and still have the  same problem.
I have replied to the private message but so far had no reply. Where do we go from here? At present I cannot confidently receive calls without it cutting out.
  • 12258 replies
  • January 25, 2024
Njames59 wrote:
Hi Lauren
FYI, iD staff who read user posts in this forum have stated elsewhere it may take at least 72-hours, possibly longer, before they’re able to reply to a PM.
In my experience, help & support via the iD social media team is the most effective iD Mobile currently provide.
  • 8358 replies
  • January 27, 2024
Hi @Njames59
We’ll respond to PMs as soon as we can, unfortunately we aren’t able to always respond quickly there.
  • January 27, 2024
I'm answering PMs but it's a slow process. Normally takes 24hrs for yourselves to reply to my answers to your questions.
Is there a quicker way? A phone number, live chat etc?
  • 8192 replies
  • January 28, 2024
Hi @Njames59,
Live Chat and Social Media may be better if you are seeking quicker answers.
However we will get to your PM as quickly as possible.
AJStubbsy
  • July 11, 2024
Did you find a solution to this problem? I have a Nothing 2a phone and I'm experiencing the same call disconnect after 2 minutes 5 seconds.
  • 8192 replies
  • July 29, 2024
Hi @AJStubbsy,
I would advise contacting our Live Chat Team and this can be raised with the team.
  • November 21, 2024
I also have this problem, and the live chat could not understand anything. Did anyone solve this problem? Strangely it is only to certain numbers not all.
  • 8358 replies
  • November 22, 2024
Hi ​@Dedd
Sorry to hear this, are you having the exact same problem with calls cutting off at 2 minutes 5 seconds or just a similar problem?
Have you tried your SIM in another device?
Are the numbers that you have this issue with standard UK numbers?
  • November 28, 2024
Hi ​@Tom ,
Thanks for getting back to me. Yep, exactly the same issue. Calls to certain numbers, standard mobile numbers in the UK, one on EE and one on Vodafone, but not to other numbers such as 02, cut off at exactly 2:05.
Sim is an ESim so can’t really be a problem? No other issues, data etc all seem fine, so resorted to VOIP calls for the moment.
Any ideas?
Edd
  • January 26, 2025
Did this issue get resolved? I get the 2 min 5 sec call disconnects and I very often cannot make outgoing calls. Extremely frustrating. I have been told to try a replacement SIM, how did your issue progress please?
I have exact same problem and so far it seems I'd think it's Sims but from these examples that's not the case and it's all different phones so what's happening and why 2 mins 5 ?
JoeKing
Silver Contributor
Forum|alt.badge.img+9
  • Silver Contributor
  • 372 replies
  • February 28, 2025
@Craigmurney1888  I'm not a staff member just a member and customer helping other's with their problems best I can. I've past on a message to a member of staff about your current problem. Hopefully they or another member of staff with get back to you.
Joe
  • 1867 replies
  • February 28, 2025
@Craigmurney1888 -
With VoLTE and WiFi calls, your device periodically send in a ‘keep-alive’ message during the call, to let the network know that the call is still active. Which phone are you using? Thanks.
