Since September, some incoming calls just end, no message or anything, just stop.
Looking at the call logs, these calls all end after 2 minutes and 5 seconds.
It is random, some days it wonts happen, other days it will happen continually until I call the person back, then it does not happen. Only happens on incoming calls.
My wife has changed phone and SIM supplier and still it persists when she calls me. Leads me to think the problem is my phone.
My phone is an Xiaomi Redmi Note Pro 5G.
Any sort of ideas to combat this frustrating issue would be welcome.
Forgot to put in the original message that my phone is a Note 12, which appears on the list you linked.
I bought the phone and SIM through ID Mobile, so I hope they are trouble free.
So, maybe I have a faulty SIM? I probably need to ask for a new one.
If these issues started Sep-2023, perhaps an Android update (on your Redmi) is to blame.
Otherwise, if nothing else has changed, maybe your iD SIM card has developed a fault. A faulty SIM card seems able to cause various mysterious service issues - so a replacement might be the answer in this case, and is worth a try.
Perhaps somehow you’ve got a faulty SIM card, @Njames59. Otherwise, maybe your Redmi handset isn’t approved by iD Mobile, for completely trouble-free use of their network.
I have changed the SIM and still have the same problem.
I have replied to the private message but so far had no reply. Where do we go from here? At present I cannot confidently receive calls without it cutting out.
FYI, iD staff who read user posts in this forum have stated elsewhere it may take at least 72-hours, possibly longer, before they’re able to reply to a PM.
In my experience, help & support via the iD social media team is the most effective iD Mobile currently provide.
I also have this problem, and the live chat could not understand anything. Did anyone solve this problem? Strangely it is only to certain numbers not all.
Thanks for getting back to me. Yep, exactly the same issue. Calls to certain numbers, standard mobile numbers in the UK, one on EE and one on Vodafone, but not to other numbers such as 02, cut off at exactly 2:05.
Sim is an ESim so can’t really be a problem? No other issues, data etc all seem fine, so resorted to VOIP calls for the moment.
Did you find a solution to this problem? I have a Nothing 2a phone and I'm experiencing the same call disconnect after 2 minutes 5 seconds.
Did this issue get resolved? I get the 2 min 5 sec call disconnects and I very often cannot make outgoing calls. Extremely frustrating. I have been told to try a replacement SIM, how did your issue progress please?
I have exact same problem and so far it seems I'd think it's Sims but from these examples that's not the case and it's all different phones so what's happening and why 2 mins 5 ?
@Craigmurney1888 I'm not a staff member just a member and customer helping other's with their problems best I can. I've past on a message to a member of staff about your current problem. Hopefully they or another member of staff with get back to you.
With VoLTE and WiFi calls, your device periodically send in a ‘keep-alive’ message during the call, to let the network know that the call is still active. Which phone are you using? Thanks.
Not the answer you were looking for?
Create a new topic and ask a question to the iD Community.
