incoming calls muffled but outgoing calls fine
  • June 9, 2024
  • 20 views
I have just joined ID mobile and whenever i receive an incoming call it is really quiet and muffled (sounds like they are underwater). But if i make an outgoing call the sound is clear. Not happy about this as i’ve just switched to id
Best answer by Tyler C
Hi there @sophiecanning, we're very sorry to hear you're having issues with coverage.
Please take a look at both of these. If you believe you should be experiencing better signal than you are, or if the networks status checker on Three's website isn't showing any upgrades or maintenance, then please let us know.
Also, please try the SIM card in another phone to see if the issue persists. If it doesn’t, then it could possibly be a device issue.
  • 5586 replies
  • June 21, 2024
