incoming texts and calls not working
Hi I moved from O2 yesterday and kept my number. I can send out texts and calls but I don't receive any. I've tried the useless 'Live Chat' which is just a bot so I would like to know how you actually sort problems out as it's not very obvious.
  • May 8, 2023
When moving networks it can take a couple of restarts to get everything working again.
If you are using an iPhone, also worth checking Apple’s advice here https://support.apple.com/en-gb/HT201422
Tom B
  • 8434 replies
  • May 9, 2023
Hi @Peeved
Are you on an iPhone or Android device?
When people call/text you, what happens on their side? Do they get any errors?
When you call/text outbound, does the correct number show for the receiver?
  • May 9, 2023
Android.
Texts give an exclamation mark and unknown number.
Phone gives unknown number.
Correct number shows for outgoing.
  • 12459 replies
  • May 9, 2023
The ‘Live Chat’ bot can be avoided if you type “talk to a person” after connecting @Peeved
The agents work until 8pm weekdays.
Tom B
  • 8434 replies
  • May 10, 2023
Hi @Peeved
Please try the following;
If you open your Messaging app and click Settings > Chat Features does it show the correct number?
If it shows the incorrect one, then head to: https://messages.google.com/disable-chat and you should be able to de-register the number. Once done, turn off the Chat Features and the phone.
Wait a few minutes and turn the device back on and re-enable Chat Features it should let you re-register/update to the correct number.
  • May 10, 2023
I've already went through all this days ago. I'm waiting to hear back from your technical team when they eventually get round to looking into it.
Mohammed H
  • 7962 replies
  • May 15, 2023
Hello @Peeved,
We’ve PMd you as above so if you need further help, just reply there.
