International calls
Why is it cheaper (at 12p per minute) to call an Australian mobile from the UK on PAYG than on a monthly contract (19p per minute)
Best answer by Mohammed
Hello @Carol ,
The out of plan rates will differ as they're not the same plans.
For a PAYG SIM, it costs 1p per MB of data.
But using data outside of your allowance on PAYM costs 10.24p per MB.
There isn't an explanation I could give you for this, besides the rates being different depending on the type of plan purchased.
View originalThe out of plan rates will differ as they're not the same plans.
