Is there a problem with the network text gateway? I am not getting texts from banks etc
For the last few days, I have not been able to receive text messages with codes for two factor authentication from banks, government etc on my iPhone. This is becoming a serious problem for me. Is there an issue with the text gateway on the network? Or is it just me?
Best answer by Tom
Hi @Richardwg
The network settings reset resets the network settings on the device and SIM card, this can be helpful to ensure that the settings on the SIM card are the correct default ones.
I do not believe there is a way to save and restore Wi-Fi settings, unless there is a feature on your device I am unaware of.
  • 12349 replies
  • February 15, 2024
My 2FA text messages are working okay, @Richardwg. I also use an iPhone.
  • 8 replies
  • February 15, 2024
If it is just me can anyone suggest why?
  • 12349 replies
  • February 15, 2024
These 2FA text messages typically originate from an organisation’s computer systems, @Richardwg
Perhaps some organisations have changed their systems, or changed their bulk SMS service provider, which means the network routing for the text messages will have changed.
Otherwise, perhaps the mobile number on record is incorrect, or your iD SIM has a fault, or your iD network accounts is misconfigured, or maybe you’ve updated your iOS recently?
In addition, Three UK (the iD Mobile network partner) have had several major network incidents recently (9th, 10th, 12th Feb ‘24) which affected call, text and data services for many customers using the Three UK network. Apparently the root cause has since been isolated and fixed.
  • 8 replies
  • February 15, 2024
I think if the UK government or one of the major banks had changed their SMS provider, it would affect a lot more people than just me! I haven’t changed my mobile number for years so there is no reason why their records should be incorrect. If the iD SIM was at fault, or my account was misconfigured, wouldn’t that affect all my texts not just the 2FA ones? My problem does seem to coincide with the Three outages which first affected me on Saturday. That’s why I wondered if there was a problem with the Three SMS gateway used by third parties to send texts to customers. Perhaps someone from iD can tell me?
  • 12349 replies
  • February 15, 2024
Good luck with getting an answer from someone at iD Mobile about this, @Richardwg
Although this is old fashioned, but have you tried:
  1. Turn OFF your handset.
  2. Remove the SIM and check it’s clean and undamaged.
  3. Wait for at least 1-hour.
  4. Insert the SIM.
  5. Turn ON your handset.
Trying this overnight might be more convenient?
  • 8 replies
  • February 15, 2024
Still don’t understand why a dirty SIM would only stop 2FA texts. Everything else is working fine.
  • 12349 replies
  • February 15, 2024
Is your SIM dirty?
Recent Three UK network incidents seem to have caused quite a few unexpected effects, for many customers at iD Mobile, SMARTY and Three UK, as evidenced by posts in the online communities of each network.
Many customers appear to have got things working again, after restarting their devices. I’ve suggested removing the SIM card to ensure the handset is definitely disconnected from the network, before reconnecting.
  • 8408 replies
  • February 16, 2024
Hi @Richardwg
We have had a recent outage that we apologise for, we believe services are back up and running, it may be worth rebooting your device to test.
Does your device’s settings have the correct phone number displayed?
Have you tried a network settings reset?
For iPhone;
For Android;
  • 8 replies
  • February 18, 2024
Thanks for all the replies. I am still in the dark about what could have caused this problem and, therefore, what is the best solution. I am reluctant to reset all my network settings if it means losing all the wifi and Bluetooth details for the multiple networks I use.
  • February 20, 2024
Hi @Richardwg,
Please can you try the network reset and let us know how you get on.
If you continue to have the same issue we can send you a PM.
  • 8 replies
  • February 20, 2024
With a network reset is there any way to save all the settings for all the wifi networks I belong to?
  • 8408 replies
  • February 21, 2024
Hi @Richardwg
I don’t believe there is unfortunately.
  • 8 replies
  • February 22, 2024
Hi Tom, I still don’t understand why resetting my network settings will fix a problem with specific texts when all the rest are working fine. I haven’t changed anything on my phone. Also, I still don’t know how to save and restore all the wifi settings that I need.
  • 8408 replies
  • February 24, 2024
Hi @Richardwg
Connor00555
  • August 12, 2024
Hello
I have recently got an ID Mobile phone and have been unable to make a bank payment online. When speaking to my bank they said that because I have changed phones the bank is no longer able to send the two factor authentication (OTP) to my phone as it doesn't recognise the number (despite the fact it is the same phone number). I was told to contact my mobile phone provider and that they should be able to fix it.
Please fix this - this has obviously not been caused by the outage in February that you mentioned above as I only got the phone two weeks ago.
I've looked at the network reset options mentioned but am unsure exactly how much it's going to reset. I also don't have exactly the same options mentioned above.
My two choices are:
- Reset mobile network settings
- Reset Bluetooth and Wi-Fi
If I have to do one of these please can you let me know everything that it's going to reset? So I am prepared for anything that may happen as a result.
Thanks in advance for any help you can provide.
  • 8408 replies
  • August 19, 2024
Hi @Connor00555
I don’t see us having mentioned the outage from February being related to your presented issue.
How are other OTP codes? How long have you had this issue?
How long have you been with iD Mobile?
Connor00555
  • August 19, 2024
Hi Tom
Thanks for getting back to me!
I think I've been ok with other OTPs but my bank's isn't working. I've been with ID since late July.
Thank you for any help you can provide.
Connor
  • 4175 replies
  • August 26, 2024
Hey there @Connor00555, sorry to hear that.
Is it only the bank you have issues with, in terms of OTP’s?
Do others work okay?
Have you contacted the bank to see if they have had any issues their end?
