Is there any way to test my APN settings before I go abroad?
Have just switched to ID from Smarty as I was enticed by the roaming data available (30GB compared to my previous provider 15GB) as I’m going to Spain & France for 6 weeks.  Then received an email from ID today telling me to check my APN settings.  Couldn’t find these in the settings menu on my iphone 15, so searched the articles and stumbled across the issues people were having with using data whilst roaming.  I’ve downloaded the unlockit.co.nz app and installed the id carrier settings, but am nervous that this wont work and I’ll be left without data whilst abroad for the 6 weeks.
So my question is whether there is any way to check if I will be able to roam using my data before I actually go abroad, or will I have to chance it?  Or do I cancel my switch and go back to my previous provider (where I could manually change the APN settings)?
Best answer by chrisfoley
Just to follow up on this with my experiences after completing my trip abroad…
Despite my concerns, the phone worked fine in Spain, France, Luxembourg, Belgium & Holland.  No service in Andorra, but that isn’t included in the roam for free (as they’re not in the EU).
As an additional bonus, whilst I was expecting to only receive 30GB of data allowance whilst roaming, I was actually able to use as much data as I needed (actually used c50GB) without having to pay any extra (I’m on an unlimited contract in the UK).  Wondering if this was intentional, or whether I got lucky?
The only suggestion I would make would be for ID to let me be able to see exactly how much data I’ve used in the app.  I can only currently check this from my statement for the previous month, so it is not real time.  Would be useful to be able to see it in the app rather than just see “unlimited”.
All in all, pleasantly surprised, although I was slightly anxious before I went...
  • 12550 replies
  • May 18, 2024
Unfortunately @chrisfoley, iD Mobile do not allow iPhone users to amend their APN settings.
Other UK providers, e.g. SMARTY, allow iPhone users to amend their APN settings.
  • 8256 replies
  • May 21, 2024
Hi @chrisfoley,
You shouldn’t have issues with APN but if you do please get in touch with us.
You can find further information at the link below:
  • 12550 replies
  • May 21, 2024
Unfortunately @chrisfoley, although @Kash has provided a link to the iD Mobile network settings, you will not be able to access these settings on an iPhone.
The “unlockit.co.nz” hack has worked for some forum members, but alas failed for others.
Performing a NETWORK RESET can help, but the correct APN settings are usually obtained from the iD roaming partner.
  • 8584 replies
  • May 23, 2024
It may also be worth trying a networks settings reset;
For iPhone;
For most Android;
For Samsung;
Resetting network settings will NOT reset any personal data (Photos, Videos, Contacts etc) only network settings.,
  • July 9, 2024
  • 5513 replies
  • July 24, 2024
Hey there @chrisfoley, we’re very glad to hear!
We shall certainly take that feedback on-board, and hope you had great travels!
MichaelT
  • 9 replies
  • August 21, 2024
I have just joined ID Mobile, having been with SMARTY previously.  I also want to check my phone is configured correctly before I go overseas.  My phone is working fine here in the UK…but I just wanted to ensure the i’s and t’s dotted here before I go on holiday.
From what I’ve read here, I see that iPhones do not allow you to check/change  the APN anywhere in the settings…which seems kind of strange when SMARTY (also on 3 network) do allow this?
Great!!! I found a tool on ID Mobile, which ensures it sends the correct settings , but when I select iPhone 14 Pro (iOS 17.5) here: -
www.idmobile.co.uk/help-and-advice/get-your-settings/settings-tool
it does absolutely nothing!
if I select just IPhone 14 Pro ie prior to the latest iOS…it gives me instructions, but the items don’t exist in the menu then, because iOS has been updated!
….so clearly this tool needs to be fixed.
I had not realised the roaming on ID Mobile was so uniformed for iPhone users.  Not being able to check this before you travel makes it kind of a lottery will it/wont it work?
I’ve seen the manual tool, so saved this just in case it goes wrong whilst I am away!
MichaelT
  • 9 replies
  • August 26, 2024
Further to this, I see the tool http://www.idmobile.co.uk/help-and-advice/get-your-settings/settings-tool?_gl=1*1nrbaup*_gcl_au*MTAwMzc3MDQ4OS4xNzI0MDg4Mzk5*_ga*NzY5MDk5MjkxLjE3MjQwODgzOTk.*_ga_XFK6G4B1Y7*MTcyNDY4ODU0NC4xNi4xLjE3MjQ2ODg2NjEuNDguMC4w
has been updated, however the iPhone 14 Pro (17.5) gives instructions to menus that don’t exist! ie these are on pre iOS 17.5 only, so the same in that the settings are not available on a phone that is on the latest version.
  • 8584 replies
  • August 29, 2024
Hi @MichaelT
We believe the settings that work in the UK will also work while abroad, however if they don’t we’d recommend the first things to do would be to perform a network settings reset and/or manually connect to networks instead of using automatic network selection.
Unfortunately on iD Mobile, it is not possible to change APN settings manually while on an iPhone, however resetting network settings sometimes does this.
MichaelT
  • 9 replies
  • August 29, 2024
Hi @Tom
Yes, I’d already done both of these steps to make sure just the IDMobile settings are the only ones on my phone.   I’ll just have to keep my fingers crossed it works when I visit Spain in a few weeks!
I do feel that ID Mobile be doing something to address this, given there are a few posts on this subject for iPhone now.
The settings tool (mentioned previously) is a road to nowhere.  It should at least display a message  “settings locked” when selecting any iPhone above iOS v 17.5,  and not display incorrect information for previous iOS versions.
  • 2014 replies
  • September 2, 2024
Hey @MichaelT,
Resetting the network settings will reconfigure the APN settings. There is currently an ongoing project to get that tool updated, as yes, iPhone/iOS has been updated.
MichaelT
  • 9 replies
  • September 2, 2024
Thanks for confirming this @Matthew T .  As far as my phone goes then my network settings have been reset, and I’ve done a manual network selection too, now back to automatic.  So….fingers crossed that it works, as it should, when I go out to Spain 🇪🇸.
I am pleased to hear that the settings tool is being overhauled too.  I haven’t been back in to look, but for anyone with limited knowledge, then this could possibly be quite misleading as it was.
MichaelT
  • 9 replies
  • September 2, 2024
@Matthew T I’ve just checked the config tool and it is still showing incorrect information ie PRE iOS 17.5 setup instructions for POST v17.5 (you cannot access APN on Apple devices after v17.5).  So, this is incorrect on the tool.
MichaelT
  • 9 replies
  • September 2, 2024
@Matthew T  so… from what I can gather from what I’ve read here.  Anyone with an Apple device iOS 17.5 upwards…then there is no menu option for Cellular Data Network (Step 4 of the configuration), so unable to check/change APN settings
I have an eSIM in my phone, but you’d expect it to be the same regardless not whether physical or eSIM.
MichaelT
  • 9 replies
  • September 2, 2024
@Matthew T my iOS version
  • 2014 replies
  • September 3, 2024
Thanks for the feedback @MichaelT.
MichaelT
  • 9 replies
  • October 5, 2024
Just an update on roaming as returned from Spain (Mallorca).  Everything worked perfectly on my iPhone 16 Pro on iOS 18.  I did reset my network settings, and carried out a manual roam/back to automatic before left the UK.
My phone, with eSIM for IDMobile connected immediately when switched off Airplane mode, 5 seconds and on the Roaming partner.
I was connected to Orange, full signal 5G for my duration (but there was a cell tower on the hotel behind!).
Best network experience had abroad.  I’ve been with Vodafone, O2, Sky and SMARTY, and seems to take forever to reconnect once you arrive with all them…unsure if this is because an eSIM vs SIM card, as first time I’ve had an eSIM.
  • 2014 replies
  • October 7, 2024
@MichaelT -
So glad you’ve had such a positive experience. Hope you enjoyed your stay in Mallorca.
