I have followed the instructions re: to keep my number, I have gone into my phone settings to change to my old number but it won’t save it.. keeps changing back to my new sim number.. so callers think I’m engaged?
keep number
Best answer by WelshPaul
This is nothing to do with id Mobile and everything to do with your device. Simply waiting for the porting process to complete before placing the SIM with a temporary number in to the device would prevent such issues. Anyway, performing a reset of the network settings usually resolves the problem.
Log in to the iD Community.
Social Login
