Whilst at work I have a good signal and had no problems until last week. My phone won’t make or receive calls, send or receive text messages. Mobile data is fine and I can check emails, whatsapp, etc. My partner is on iD mobile too but phone works fine. As soon as I drive a mile away the phone works as it should. I’ve updated the phone, cleared cache, etc. It’s been like this a week. I put the sim in a different phone and it worked. It must be to do with my phone settings but unsure what. I have a redmi note 9. Any suggestions gratefully received, many thanks..
Location problems
Best answer by Kash
It does sound like it was a handset issue.
Log in to the iD Community.
Social Login
