Majorca Roaming
Is Majorca included with Spain for free roaming?
Yes @Des McLoughlin, you can use your iD plan’s calls, texts and mobile data allowances while roaming in Majorca.
Your plan’s inclusive EU roaming data allowance might be less than in the UK though - check online from the iD website at https://www.idmobile.co.uk/help-and-advice/eu-roaming/fair-usage-policy.
  • 12421 replies
  • July 24, 2023
Mohammed H
  • 7962 replies
  • July 26, 2023
Hey @Des McLoughlin,
As confirmed above by @andewhite,
It’s included in roaming but do check your data as a fair usage policy applies and this depends on when you purchased to determine which of the two fair usage policies apply.
